vserver nvme subsystem show
Display NVMe target subsystems
The vserver nvme subsystem show command displays information for NVMe subsystems.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Use this parameter to display the NVMe subsystems that match the Vserver that you specify.
[-subsystem <text>] - Subsystem
Use this parameter to display the NVMe subsystem that matches the name that you specify.
[-ostype {aix|linux|vmware|windows}] - OS Type
Use this parameter to display the NVMe subsystems that match this parameter value.
[-comment <text>] - Comment
[-target-nqn <text>] - Target NQN
[-serial-number <text>] - Serial Number
[-default-io-queue-count <integer>] - Default Number of Host I/O Queue Pairs
Specifies the default maximum IO queue count inherited by hosts added to this subsystem.
[-default-io-queue-depth <integer>] - Default Host I/O Queue Depth
Specifies the default maximum IO queue depth inherited by hosts added to this subsystem.
[-uuid <UUID>] - UUID
Use this parameter to display the NVMe subsystems that have UUIDs matching the parameter value.
[-delete-on-unmap {true|false}] - Delete on Unmap
Specifies whether the subsystem should be deleted automatically when it is no longer mapped to a namespace.
[-vendor-uuids <UUID>,…​] - Vendor UUIDs
Use this parameter to display the NVMe subsystems that have vendor-specific UUIDs that match the parameter value.
cluster1::*> vserver nvme subsystem show -vserver vs_1
Vserver Subsystem    Target NQN
vs_1
        ss1          nqn.1992-08.netapp.com:sn.ccb5a7d5d9d311e7924e005056b45113:subsystem.ss1
        ss2          nqn.1992-08.netapp.com:sn.ccb5a7d5d9d311e7924e005056b45113:subsystem.ss2
2 entries were displayed.
