Command reference
vserver nvme subsystem show
Display NVMe target subsystems
The vserver nvme subsystem show command displays information for NVMe subsystems.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Use this parameter to display the NVMe subsystems that match the Vserver that you specify.
[-subsystem <text>] - Subsystem
Use this parameter to display the NVMe subsystem that matches the name that you specify.
[-ostype {aix|linux|vmware|windows}] - OS Type
Use this parameter to display the NVMe subsystems that match this parameter value.
[-comment <text>] - Comment
[-target-nqn <text>] - Target NQN
[-serial-number <text>] - Serial Number
[-uuid <UUID>] - UUID
Use this parameter to display the NVMe subsystems that have UUIDs matching the parameter value.
[-delete-on-unmap {true|false}] - Delete on Unmap (privilege: advanced)
Specifies whether the subsystem should be deleted automatically when it is no longer mapped to a namespace.
[-vendor-uuids <UUID>,…​] - Vendor UUIDs (privilege: advanced)
Use this parameter to display the NVMe subsystems that have vendor-specific UUIDs that match the parameter value.
[-peer-vserver-name <text>] - Peer Vserver Name
Selects the subsystems that match this parameter value. The peer-vserver-name is the local name of the peer Vserver, as reported by the vserver peer show -fields peer-vserver command. When set, the subsystem and its hosts and maps to namespaces are replicated to the peer cluster.
[-replication-error <text>] - Replication Error
Selects the subsystems that match this parameter value. This field provides information about asynchronous errors encountered while replicating this subsystem. Subsystems within a peering relationship are replicated in the same stream, so the error reported here might be related to this subsystem or a prior replicated subsystem that is now blocking the replication of this subsystem. Both the error information and the subsystem encountering the error are reported. If the error is configuration related, it can be corrected on the referenced subsystem. The replication is retried using exponential backoff up to a maximum of one retry every 5 minutes. Every operation on the same stream triggers an immediate retry and restarts the exponential backoff starting with a 1 second delay. If the error is system related, the retries should correct the error when the system enters a healthy state.
[-replication-error-subsystem <text>] - Replication Error Subsystem
Selects the subsystems that match this parameter value. The name of the subsystem encountering the error reported by the 'replication-error' field.
cluster1::*> vserver nvme subsystem show -vserver vs_1
Vserver Subsystem    Target NQN
vs_1
        ss1          nqn.1992-08.netapp.com:sn.ccb5a7d5d9d311e7924e005056b45113:subsystem.ss1
        ss2          nqn.1992-08.netapp.com:sn.ccb5a7d5d9d311e7924e005056b45113:subsystem.ss2
2 entries were displayed.
