snaplock event-retention policy show
PDF of this doc site
Creating your file...
Show SnapLock Event Based Retention policies for a Vserver
The snaplock event-retention policy show
command is used to show Event Based Retention (EBR) policies for a Vserver. A policy consists of a policy-name
and a retention-period
. The command output depends on the parameter or parameters specified. If no parameters are specified, all policies for all vservers will be displayed. If one or more parameters are specified, only those entries matching the specified values will be displayed. Only a user with security login role vsadmin-snaplock
is allowed to perform this operation.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name-
If this parameter is specified, the command displays all EBR policies that match the specified Vserver.
[-name <text>]
- Policy Name-
name
. [-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]
- Event Retention Period-
retention-period
The following example displays all event-retention policies for vserver "vs1":
vs1::> snaplock event-retention policy show Vserver Name Retention Period ----------------- ------------------- -------------------- vs1 p1 10 years vs1 p2 5 years
