The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system ha interconnect statistics clear-port-symbol-error
PDF of this doc site
Creating your file...
Your file is ready
Clear the high-availability interconnect port symbol errors
The system ha interconnect statistics clear-port-symbol-error
command clears the high-availability interconnect device port symbol errors. This command is supported only on FAS2500 series nodes in the cluster.
To display the high-availability interconnect device port statistics, use the statistics show -object ic_hw_port_stats command. |
-node <nodename>
- Node (privilege: advanced)-
Selects the nodes that match this parameter value.
cluster1::*> system ha interconnect statistics clear-port-symbol-error -node ic-f2554-03
