system ha interconnect statistics clear-port-symbol-error
Clear the high-availability interconnect port symbol errors
The system ha interconnect statistics clear-port-symbol-error
command clears the high-availability interconnect device port symbol errors. This command is supported only on FAS2500 series nodes in the cluster.
To display the high-availability interconnect device port statistics, use the statistics show -object ic_hw_port_stats command. |
-node <nodename>
- Node (privilege: advanced)-
Selects the nodes that match this parameter value.
cluster1::*> system ha interconnect statistics clear-port-symbol-error -node ic-f2554-03
