vserver migrate source-cleanup
Perform vserver cleanup on the source cluster
This command cleans up the migrate source Vserver.
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
Name of the Vserver to be deleted on the source cluster.
[-force {true|false}]
- Force option to override veto checks (privilege: advanced)-
This parameter is used to forcibly delete the Vserver.
cluster1::> vserver migrate source-cleanup -vserver test
