The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver cifs security-encryption-required-dc-connections-prepare-to-downgrade
PDF of this doc site
Creating your file...
Your file is ready
Disabled encryption-required-for-dc-connections option and capability for downgrade.
The vserver cifs security-encryption-required-dc-connections-prepare-to-downgrade
prepares the cluster for downgrade by disabling SMB3.encryption.required.dc.connection capability
cluster1::*> vserver cifs security-encryption-required-dc-connections-prepare-to-downgrade
