event filter delete
Delete existing event filters
The event filter delete
command deletes an existing event filter, along with all its rules.
The system-defined event filters cannot be deleted.
For more information, see the event filter create command.
-filter-name <text>
- Filter Name-
Use this mandatory parameter to specify the name of the event filter to delete.
The following example deletes an event filter named filter1:
cluster1::> event filter show Filter Rule Rule SNMP Trap Name Posn Type Message Name Severity Type Parameters ----------- ---- -------- ---------------- ------------- --------- ----------- default-trap-events 1 include * EMERGENCY, ALERT * *=* 2 include * * Standard, Built-in *=* 3 exclude * * * *=* filter1 1 include wafl.* EMERGENCY * *=* 2 exclude * * * *=* important-events 1 include * EMERGENCY, ALERT * *=* 2 include callhome.* ERROR * *=* 3 exclude * * * *=* no-info-debug-events 1 include * EMERGENCY, ALERT, ERROR, NOTICE * *=* 2 exclude * * * *=* 10 entries were displayed. cluster1::> event filter delete -filter-name filter1 cluster1::> event filter show Filter Rule Rule SNMP Trap Name Posn Type Message Name Severity Type Parameters ----------- ---- -------- ---------------- ------------- --------- ----------- default-trap-events 1 include * EMERGENCY, ALERT * *=* 2 include * * Standard, Built-in *=* 3 exclude * * * *=* important-events 1 include * EMERGENCY, ALERT * *=* 2 include callhome.* ERROR * *=* 3 exclude * * * *=* no-info-debug-events 1 include * EMERGENCY, ALERT, ERROR, NOTICE * *=* 2 exclude * * * *=* 8 entries were displayed.
