ONTAP commands
snapmirror object-store config delete
Delete SnapMirror object store configuration
The snapmirror object-store config delete command removes an existing object store configuration in Data ONTAP.
-vserver <vserver name> - Vserver Name
This parameter specifies the vserver name on which the object store configuration has been configured.
-object-store-name <text> - Object Store Configuration Name
This parameter specifies the object store configuration to be deleted.
