Command reference
snapmirror object-store config delete
Delete SnapMirror object store configuration
The snapmirror object-store config delete command removes an existing object store configuration in ONTAP.
-vserver <vserver name> - Vserver Name
This parameter specifies the vserver name on which the object store configuration has been configured.
-object-store-name <text> - Object Store Configuration Name
This parameter specifies the object store configuration to be deleted.
The following example deletes an object store configuration named objectStoreName.
cluster1::*> snapmirror object-store config delete
        -object-store-name objectStoreName
