The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network options switchless-cluster show
PDF of this doc site
Creating your file...
Your file is ready
Display switchless cluster network options
The network options switchless-cluster show command displays the attributes of a switchless cluster.
The following example displays the attributes of the switchless cluster: cluster1::*> network options switchless-cluster show Enable Switchless Cluster: true
