network options switchless-cluster show
Display switchless cluster network options
The network options switchless-cluster show command displays the attributes of a switchless cluster.
The following example displays the attributes of the switchless cluster: cluster1::*> network options switchless-cluster show Enable Switchless Cluster: true
