      network options switchless-cluster show
Display switchless cluster network options
The network options switchless-cluster show command displays the attributes of a switchless cluster.
The following example displays the attributes of the switchless cluster:
            cluster1::*> network options switchless-cluster show
            Enable Switchless Cluster: true
 PDFs
PDFs
