system controller pcicerr threshold modify
PDF of this doc site
Creating your file...
Your file is ready
Modify the Node PCIe error alert threshold
The system controller pcicerr threshold modify
command modifies node-wide PCIe correctable error threshold counts in the cluster.
[-pcie-cerr-threshold <integer>]
- Corr. Error Limit-
The PCIe error threshold count that would trigger an alert if exceeded.
[-nvram-bb-threshold <integer>]
- NVRAM Bad Block limit-
The NVRAM bad block threshold count that would trigger an alert if exceeded.
The example below displays the information about setting node-wide PCIe error threshold count in the cluster:
cluster1::> system controller threshold modify -pcie-cerr-threshold 100
