      system controller pcicerr threshold modify
Modify the Node PCIe error alert threshold
The system controller pcicerr threshold modify command modifies node-wide PCIe correctable error threshold counts in the cluster.
- [-pcie-cerr-threshold <integer>]- Corr. Error Limit
The PCIe error threshold count that would trigger an alert if exceeded.
- [-nvram-bb-threshold <integer>]- NVRAM Bad Block limit
The NVRAM bad block threshold count that would trigger an alert if exceeded.
The example below displays the information about setting node-wide PCIe error threshold count in the cluster:
cluster1::> system controller threshold modify -pcie-cerr-threshold 100
 PDFs
PDFs
