The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume efficiency promote
PDF of this doc site
Creating your file...
Your file is ready
Add a volume to the preferred set of volumes for efficiency processing
Use the volume efficiency promote
command to promote a volume from deprioritized state back to auto state.
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name (privilege: advanced) -
This specifies the name of the volume on which auto scheduling needs to be restarted.
-path </vol/volume>
- Volume Path (privilege: advanced) } -
This specifies the volume path on which auto scheduling needs to be restarted.
The following example promotes a volume from deprioritized state back to auto state.
cluster1::*> volume efficiency promote -vserver vs1 -volume vol1
