volume efficiency promote
Add a volume to the preferred set of volumes for efficiency processing
Use the volume efficiency promote
command to promote a volume from deprioritized state back to auto state.
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name (privilege: advanced) -
This specifies the name of the volume on which auto scheduling needs to be restarted.
-path </vol/volume>
- Volume Path (privilege: advanced) } -
This specifies the volume path on which auto scheduling needs to be restarted.
The following example promotes a volume from deprioritized state back to auto state.
cluster1::*> volume efficiency promote -vserver vs1 -volume vol1
