volume efficiency promote
Add a volume to the preferred set of volumes for efficiency processing
Use the volume efficiency promote command to promote a volume from deprioritized state back to auto state.
-vserver <vserver name> - Vserver Name
This specifies the Vserver on which the volume is located.
{ -volume <volume name> - Volume Name
This specifies the name of the volume on which auto scheduling needs to be restarted.
| -path </vol/volume> - Volume Path }
This specifies the volume path on which auto scheduling needs to be restarted.
The following example promotes a volume from deprioritized state back to auto state.
cluster1::*> volume efficiency promote -vserver vs1 -volume vol1
