The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system switch ethernet delete
PDF of this doc site
Creating your file...
Your file is ready
Delete information about an Ethernet switch (cluster, management or storage).
The system switch ethernet delete
command disables switch health monitoring for an Ethernet switch (cluster, management or storage).
-device <text>
- Device Name-
Specifies the name of the switch.
[-force <true>]
- Force Delete (privilege: advanced)-
Specifies if the delete operation is forced.
cluster1::> system switch ethernet delete -device SwitchA
Disables monitoring for the switch named SwitchA.
cluster1::> system switch ethernet delete -device SwitchA -force
Forcefully disables monitoring for the switch named SwitchA. (privilege: advanced)
