ONTAP commands
vserver cifs security-encryption-required-dc-connections-prepare-to-downgrade
Disabled encryption-required-for-dc-connections option and capability for downgrade.
The vserver cifs security-encryption-required-dc-connections-prepare-to-downgrade prepares the cluster for downgrade by disabling SMB3.encryption.required.dc.connection capability
cluster1::*> vserver cifs security-encryption-required-dc-connections-prepare-to-downgrade
Looking for answers?
Try Doc, our Gen AI Assistant.
