lun delete
PDF of this doc site
Creating your file...
Delete the LUN
This command deletes a LUN from a specified Vserver and volume. If the LUN is mapped and online, the force option is required to delete it.
If a LUN is mapped to an initiator group, you can unmap it by using the lun unmap command. If a LUN is online, you take it offline by using the lun offline
command.
If you create a LUN from a file, you cannot remove the file while the LUN is linked to it. If you want to remove the file, you must first delete the LUN. |
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-path <path>
- LUN Path -
Specifies the path of the LUN you want to delete. Examples of correct LUN paths are
/vol/vol1/lun1
and/vol/vol1/qtree1/lun1
-volume <volume name>
- Volume Name -
Specifies the volume that contains the LUN you want to delete.
[-qtree <qtree name>]
- Qtree Name-
Specifies the qtree that contains the LUN you want to delete.
-lun <text>
- LUN Name }-
Specifies the LUN that you want to delete.
[-f, -force <true>]
- Force Deletion of an Online and Mapped LUN-
Force deletion of an online LUN that is mapped to an initiator group.
[-force-fenced <true>]
- Force Deletion of a Fenced LUN-
Force deletion of a LUN that is currently fenced.
cluster1::> lun delete -vserver vs1 -path /vol/vol1/lun1
Deletes the LUN at path /vol/vol1/lun1 on Vserver vs1.
