The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system license license-manager modify
PDF of this doc site
Creating your file...
Your file is ready
The ` system license license-manager modify ` command modifies the configuration information for the License Manager the system is using.
[-host <text>]
- License Manager Host (privilege: advanced)-
Sets the specified host, which can either be a fully qualified domain name (FQDN) or an IP address.
The following example modifies information about the License Manager configuration:
cluster1::*> system license license-manager modify -host myhost.mycompany.com
