Command reference
system license license-manager modify
The ` system license license-manager modify ` command modifies the configuration information for the License Manager the system is using.
[-host <text>] - License Manager Host (privilege: advanced)
Sets the specified host, which can either be a fully qualified domain name (FQDN) or an IP address.
The following example modifies information about the License Manager configuration:
cluster1::*> system license license-manager modify -host myhost.mycompany.com
