statistics top client show
PDF of this doc site
Creating your file...
Most active NFS and CIFS clients
This command continuously displays performance data for the top NFS and CIFS clients at a regular interval. The command output displays data in the following columns:
Client - client name.
Vserver - vserver name.
Node - node name.
Total Ops - total number of operations per second.
Total (Bps) - total throughput in bytes per second.
[-node {<nodename>|local}]
- Node-
Selects the node for which you want to display performance data.
[-sort-key <text>]
- Column to Sort By-
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer>
- Interval-
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer>
- Iterations-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer>
- Maximum Number of Instances-
Specifies maximum number of top clients to display. The default setting is 10.
The following example displays top client statistics:
cluster1::> statistics top client show cluster-1 : 12/31/1969 16:00:04 *Total Total Client Vserver Node Ops (Bps) ------------------ --------- ------------- ------ ----- 172.17.236.53:938 vserver01 cluster-node2 9 80 172.17.236.160:898 vserver02 cluster-node1 6 50 [...]
