ONTAP commands
statistics top client show
Most active NFS and CIFS clients
This command continuously displays performance data for the top NFS and CIFS clients at a regular interval. The command output displays data in the following columns:
  • Client - client name.
  • Vserver - vserver name.
  • Node - node name.
  • Total IOPs - total number of operations per second.
  • Total (Bps) - total throughput in bytes per second.
[-node {<nodename>|local}] - Node
Selects the node for which you want to display performance data.
[-sort-key <text>] - Column to Sort By
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer> - Interval
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer> - Iterations
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer> - Maximum Number of Instances
Specifies maximum number of top clients to display. The default setting is 10.
The following example displays top client statistics:
cluster1::> statistics top client show
cluster-1 : 12/31/1969 16:00:04
*Total Total
            Client   Vserver          Node    Ops (Bps)
 172.17.236.53:938 vserver01 cluster-node2      9    80
172.17.236.160:898 vserver02 cluster-node1      6    50
