The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system ha interconnect ood clear-performance-statistics
PDF of this doc site
Creating your file...
Your file is ready
Clear performance statistics
The system ha interconnect ood clear-performance-statistics
command enables you to clear all the performance statistics collected for the out-of-order delivery-capable high-availability interconnect device. This command is only supported on FAS2500 series nodes in the cluster.
-node <nodename>
- Node (privilege: advanced)-
This mandatory parameter specifies which node will have the performance statistics cleared. The value "local" specifies the current node.
cluster1::*> system ha interconnect ood clear-performance-statistics -node ic-f2554-03
