ONTAP commands
system ha interconnect ood clear-performance-statistics
Clear performance statistics
The system ha interconnect ood clear-performance-statistics command enables you to clear all the performance statistics collected for the out-of-order delivery-capable high-availability interconnect device. This command is only supported on FAS2500 series nodes in the cluster.
-node <nodename> - Node (privilege: advanced)
This mandatory parameter specifies which node will have the performance statistics cleared. The value "local" specifies the current node.
cluster1::*> system ha interconnect ood clear-performance-statistics -node ic-f2554-03
