ONTAP commands
network options port-health-monitor disable-monitors
Disable one or more port health monitors
This command disables the given port health monitors for the given IPspaces in the cluster.
-ipspace <IPspace> - IPspace Name (privilege: advanced)
The name of the IPspace for which the specified port health monitors are disabled.
-health-monitors {l2-reachability|link-flapping|crc-errors|vswitch-link} - List of Port Health Monitors to Disable (privilege: advanced)
The port health monitors to disable.
The following example disables the "l2_reachability" health monitor for the "Default" IPspace.
Note The status of the "link_flapping" monitor is unaffected by the command.
cluster1::*> network options port-health-monitor show
IPspace         Enabled Port Health Monitors
Cluster         l2_reachability,
                link_flapping
Default         l2_reachability,
                link_flapping
2 entries were displayed.
cluster1::*> network options port-health-monitor disableMonitors -ipspace Default -health-monitors l2_reachability
                link_flapping
Default         link_flapping
