The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system node usb-ports modify
PDF of this doc site
Creating your file...
Your file is ready
Modify the state of the external USB ports on the next boot
The system node usb-ports modify
command allows the user to change the state of the external USB ports on the next boot.
-node {<nodename>|local}
- Node That Owns the External USB Ports (privilege: advanced)-
This parameter specifies which node the external USB state will be modified.
[-is-disabled-next-boot {true|false}]
- State of the External USB Ports on the Next Boot (privilege: advanced)-
If set to ` true ` the external USB ports on the specified node will be disabled on the next boot.
The following example disables the external USB ports for node1 on the next boot:
cluster1::> system node usb-ports modify -node node1 -is-disabled-next-boot true ALERT: A reboot is required for changes to take effect.
