system node usb-ports modify
Modify the state of the external USB ports on the next boot
The system node usb-ports modify command allows the user to change the state of the external USB ports on the next boot.
-node {<nodename>|local}- Node That Owns the External USB Ports (privilege: advanced)-
This parameter specifies which node the external USB state will be modified.
[-is-disabled-next-boot {true|false}]- State of the External USB Ports on the Next Boot (privilege: advanced)-
If set to ` true ` the external USB ports on the specified node will be disabled on the next boot.
The following example disables the external USB ports for node1 on the next boot:
cluster1::> system node usb-ports modify -node node1 -is-disabled-next-boot true ALERT: A reboot is required for changes to take effect.
