statistics top file show
PDF of this doc site
Creating your file...
Most actively accessed files
This command continuously displays performance data for top files at a regular interval. The command output displays data in the following columns:
File - file name.
Volume - volume name.
Vserver - vserver name.
Aggregate - aggregate name.
Node - node name.
Total Ops - total number of operations per second.
Total (Bps) - total throughput in bytes per second.
[-node {<nodename>|local}]
- Node-
Selects the node for which you want to display performance data.
[-sort-key <text>]
- Column to Sort By-
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer>
- Interval-
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer>
- Iterations-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer>
- Maximum Number of Instances-
Specifies maximum number of top files to display. The default setting is 10.
The following example displays top files statistics:
cluster1::> statistics top file show cluster-1 : 12/31/1969 16:00:04 *Total Total File Volume Vserver Aggregate Node Ops (Bps) --------------------- ------- --------- --------- ------------- ------ ----- /vol/vol01/clus/cache vol01 vserver01 aggr1 cluster-node2 9 80 /vol/vol02 vol02 vserver02 aggr2 cluster-node1 6 50 [...]
