ONTAP commands
statistics top file show
Most actively accessed files
This command continuously displays performance data for top files at a regular interval. The command output displays data in the following columns:
  • Total IOPS - total number of input/output operations per second.
  • Node - node name.
  • Vserver - vserver name.
  • Aggregate - aggregate name.
  • Volume - volume name.
  • File - file name.
[-node {<nodename>|local}] - Node
Selects the node for which you want to display performance data.
[-sort-key <text>] - Column to Sort By
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer> - Interval
Specifies, in seconds, the interval between statistics updates. The default setting is 30 seconds.
-iterations <integer> - Iterations
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer> - Maximum Number of Instances
Specifies maximum number of top files to display. The default setting is 10.
The following example displays top files statistics:
cluster1::> statistics top file show
cluster-1 : 12/31/1969 16:00:04
*Estimated
     Total
      IOPS          Node   Vserver Aggregate Volume                  File
         9 cluster-node2 vserver01     aggr1  vol01 /vol/vol01/clus/cache
         6 cluster-node1 vserver02     aggr2  vol02            /vol/vol02
