system switch ethernet fan show
PDF of this doc site
Creating your file...
Display fan information for Ethernet switches (cluster, management and storage).
The system switch ethernet fan show
command displays the status of fans on the monitored Ethernet switches.
[-fields <fieldname>,…]
Selects the specified fields.
[-instance ]
Displays detailed information for all fans on all switches.
[-device <text>]
- Switch Name-
Selects the fans that belong to the specified switch.
[-fan-name <text>]
- Fan or Fan Tray Name-
Selects the fans that match the specified fan name or fan tray name.
[-index <integer>]
- Sensor Index-
Selects the fans that match the specified sensor index.
[-fan-type {single|tray}]
- Single Fan or Fan Tray-
Selects the fans that match the specified fan type.
[-fan-status {operational|failed|not-operational|not-present|unknown}]
- Fan Status-
Selects the fans that match the specified operational status.
[-display-name <text>]
- Fan Display Name-
Selects the fans that match the specified display name.
[-unique-name <text>]
- Fan Unique Name-
Selects the fan that matches the specified unique name.
[-container-name <text>]
- Fan Container Name-
Selects the fans that match the specified container name.
[-is-psu-fan {yes|no}]
- Is Power Supply Unit Fan-
Selects the fans that are PSU fans (
yes
) or are not PSU fans (no
). [-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}]
- Health Monitor-
Selects the fans that the specified health monitor continuously monitors.
[-error-description <text>]
- Error Description-
Selects the fans that match the specified error description.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}]
- Resource Status-
Selects the fans that match the specified status.
cluster1::> system switch ethernet fan show Switch: SwitchA Is PSU Fan Type Fan Status Container Fan Error ------------------ ------ ---------------- -------------- ------ ------------ Fan Module-1 tray operational FanBay-1 no Fan Module-2 tray operational FanBay-2 no Switch: SwitchB Is PSU Fan Type Fan Status Container Fan Error ------------------ ------ ---------------- -------------- ------ ------------ Fan Module-1 tray operational FanBay-1 no Fan Module-2 tray operational FanBay-2 no
The above example displays the fans and their status on the switches names SwitchA and SwitchB.
