ONTAP commands
system switch ethernet fan show
Display fan information for Ethernet switches (cluster and storage).
The system switch ethernet fan show command displays the status of fans on the monitored Ethernet switches.
{ [-fields <fieldname>,…​]
Selects the specified fields.
| [-instance ] }
Displays detailed information for all fans on all switches.
[-device <text>] - Switch Name
Selects the fans that belong to the specified switch.
[-fan-name <text>] - Fan or Fan Tray Name
Selects the fans that match the specified fan name or fan tray name.
[-index <integer>] - Sensor Index
Selects the fans that match the specified sensor index.
[-fan-type {single|tray}] - Single Fan or Fan Tray
Selects the fans that match the specified fan type.
[-fan-status {operational|failed|not-operational|not-present|unknown}] - Fan Status
Selects the fans that match the specified operational status.
[-display-name <text>] - Fan Display Name
Selects the fans that match the specified display name.
[-unique-name <text>] - Fan Unique Name
Selects the fan that matches the specified unique name.
[-container-name <text>] - Fan Container Name
Selects the fans that match the specified container name.
[-is-psu-fan {yes|no}] - Is Power Supply Unit Fan
Selects the fans that are PSU fans (yes ) or are not PSU fans (no ).
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}] - Health Monitor
Selects the fans that the specified health monitor continuously monitors.
[-error-description <text>] - Error Description
Selects the fans that match the specified error description.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}] - Resource Status
Selects the fans that match the specified status.
cluster1::> system switch ethernet fan show
Switch: SwitchA
                                                          Is PSU
Fan                Type   Fan Status       Container      Fan    Error
Fan Module-1       tray   operational      FanBay-1       no
Fan Module-2       tray   operational      FanBay-2       no
Switch: SwitchB
                                                          Is PSU
The above example displays the fans and their status on the switches names SwitchA and SwitchB.
