statistics qtree show
PDF of this doc site
Creating your file...
Qtree I/O operation rates
This command continuously displays performance data for qtrees at a regular interval. The command output displays data in the following columns:
Qtree - Qtree name.
Vserver - Vserver name.
Volume - Volume name.
NFS Ops - NFS operations per second.
CIFS Ops - CIFS operations per second.
Internal Ops - Internal operations per second.
Total Ops - Total number of operations per second.
[-qtree <text>]
- Qtree-
Selects the qtree for which you want to display performance data. The qtree name has to be given in the format "vol_name/qtree_name"
[-vserver <vserver name>]
- Vserver-
Selects the Vserver for which you want to display performance data.
[-volume <text>]
- Volume-
Selects the volume for which you want to display performance data.
[-sort-key <text>]
- Column to Sort By-
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer>
- Interval-
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer>
- Iterations-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer>
- Maximum Number of Instances-
Specifies the maximum number of qtrees to display. The default setting is 25.
The following example displays qtree statistics:
C1_sti20-vsim-ucs429g_1520278254::> statistics qtree show C1_sti20-vsim-ucs429g_1520278254 : 3/14/2018 15:40:46 NFS CIFS Internal *Total Qtree Vserver Volume ops ops ops ops ----------- ------- ------- --- ---- -------- ------ flexvol/qt1 vs0 flexvol 7 0 0 7 dp_vol/qt9 vs0 dp_vol 7 0 0 7 dp_vol/qt8 vs0 dp_vol 7 0 0 7 [...]
