ONTAP 9.13.1 commands
metrocluster check connection show
Display the check results of connections for nodes in a MetroCluster over IP configuration
The metrocluster check connection show command displays the check results of connections for nodes in a MetroCluster over IP configuration.
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays only the fields that you specify.
| [-instance ] }
If this parameter is specified, the command displays detailed information about all entries.
[-dr-group-id <integer>] - DR Group ID
If this parameter is specified, the command displays information for the matching DR group.
[-cluster-uuid <UUID>] - Cluster UUID
If this parameter is specified, the command displays information for the matching cluster specified by uuid.
[-cluster <Cluster name>] - Cluster Name
If this parameter is specified, the command displays information for the matching cluster.
[-node-uuid <UUID>] - Node UUID
If this parameter is specified, the command displays information for the matching node specified by uuid.
[-node <text>] - Node Name
If this parameter is specified, the command displays information for the matching nodes.
[-home-port {<netport>|<ifgrp>}] - Home Port
If this parameter is specified, the command displays information for the matching home-port.
[-relationship-type <Roles of MetroCluster Nodes>] - Relationship Role Type
If this parameter is specified, the command displays information for the matching relationship-type.
[-source-address <IP Address>] - Source Network Address
If this parameter is specified, the command displays information for the matching source address.
[-destination-address <IP Address>] - Destination Network Address
If this parameter is specified, the command displays information for the matching destination address.
[-partner-cluster-uuid <UUID>] - Partner Cluster UUID
If this parameter is specified, the command displays information for the matching partner-cluster-uuid.
[-partner-node-uuid <UUID>] - Partner Node UUID
If this parameter is specified, the command displays information for the matching partner-node-uuid.
[-partner-node <text>] - Partner Node Name
If this parameter is specified, the command displays information for the matching partner-node.
[-partner-type <text>] - Partner Relationship Type
If this parameter is specified, the command displays information for the matching partner-type.
[-config-state <text>] - Configuration State
If this parameter is specified, the command displays information for the matching config-state.
[-config-error-info <text>] - Configuration Error Information
If this parameter is specified, the command displays information for the matching config-error-info.
[-check-result {ok|warning|not-run|not-applicable}] - Check Connection Result
If this parameter is specified, the command displays information for the matching check-result.
[-check-ping-error-info <text>] - Check Connection Ping Error Info
If this parameter is specified, the command displays information for the matching check-ping-error-info.
[-check-mtu-size-error-info <text>] - Check Connection MTU Size Error Info
If this parameter is specified, the command displays information for the matching check-mtu-size-error-info.
[-check-storage-error-info <text>] - Check Connection Storage Error Info
If this parameter is specified, the command displays information for the matching check-storage-error-info.
The following example shows the output of the metrocluster check connection show command:
clusA::>  metrocluster check connection show
DR                    Source          Destination
Group Cluster Node    Network Address Network Address Partner Type Config State
1     cluster-A
              node-A1
                 Home Port: e0f
                      10.140.113.214  10.140.113.216  HA Partner   completed
              Check Result: ok
                 Home Port: e0f
                      10.140.113.214  10.140.113.218  DR Partner   completed
              Check Result: ok
                 Home Port: e0f
                      10.140.113.214  10.140.113.249  DR Auxiliary completed
              Check Result: ok
                 Home Port: e0g
                      10.140.113.215  10.140.113.217  HA Partner   completed
              Check Result: ok
                 Home Port: e0g
                      10.140.113.215  10.140.113.248  DR Partner   completed
              Check Result: ok
                 Home Port: e0g
                      10.140.113.215  10.140.113.25   DR Auxiliary completed
              Check Result: ok
              node-A2
                 Home Port: e0f
                      10.140.113.216  10.140.113.214  HA Partner   completed
              Check Result: ok
                 Home Port: e0f
                      10.140.113.216  10.140.113.249  DR Partner   completed
              Check Result: ok
                 Home Port: e0f
                      10.140.113.216  10.140.113.218  DR Auxiliary completed
              Check Result: ok
                 Home Port: e0g
                      10.140.113.217  10.140.113.215  HA Partner   completed
              Check Result: ok
                 Home Port: e0g
                      10.140.113.217  10.140.113.25   DR Partner   completed
              Check Result: ok
                 Home Port: e0g
                      10.140.113.217  10.140.113.248  DR Auxiliary completed
              Check Result: ok
      cluster-B
              node-B1
                 Home Port: e0f
                      10.140.113.218  10.140.113.249  HA Partner   completed
              Check Result: ok
                 Home Port: e0f
                      10.140.113.218  10.140.113.214  DR Partner   completed
              Check Result: ok
                 Home Port: e0f
                      10.140.113.218  10.140.113.216  DR Auxiliary completed
              Check Result: ok
                 Home Port: e0g
                      10.140.113.248  10.140.113.25   HA Partner   completed
              Check Result: ok
                 Home Port: e0g
                      10.140.113.248  10.140.113.215  DR Partner   completed
              Check Result: ok
                 Home Port: e0g
                      10.140.113.248  10.140.113.217  DR Auxiliary completed
              Check Result: ok
              node-B2
                 Home Port: e0f
                      10.140.113.249  10.140.113.218  HA Partner   completed
              Check Result: ok
                 Home Port: e0f
                      10.140.113.249  10.140.113.216  DR Partner   completed
              Check Result: ok
                 Home Port: e0f
                      10.140.113.249  10.140.113.214  DR Auxiliary completed
              Check Result: ok
                 Home Port: e0g
                      10.140.113.25   10.140.113.248  HA Partner   completed
              Check Result: ok
                 Home Port: e0g
                      10.140.113.25   10.140.113.217  DR Partner   completed
              Check Result: ok
                 Home Port: e0g
                      10.140.113.25   10.140.113.215  DR Auxiliary completed
              Check Result: ok
24 entries were displayed.
