system bridge refresh
Refresh bridge info
The system bridge refresh command triggers a refresh of the SNMP data for the MetroCluster FC switches and FC-to-SAS bridges. It does not do anything if the refresh is already going on. The FC switches and FC-to-SAS bridges must have been previously added for monitoring by using the system switch fiber-channel add and system bridge add commands respectectively.
The following command triggers a refresh for the SNMP data:
cluster1::*> system bridge refresh cluster1::*>
