storage tape library config show
PDF of this doc site
Creating your file...
Display connectivity to back-end storage tape libraries.
This command displays information such as how the storage tape libraries connect to the cluster, LUN groups, number of LUNs, WWPN, and switch port information. Use this command to verify the cluster's storage tape library configuration or to assist in troubleshooting.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-switch ]
If you specify this parameter, switch port information is shown.
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Controller Name-
The name of the clustered node for which information is being displayed.
[-group <integer>]
- LUN Group-
A LUN group is a set of LUNs that shares the same path set.
[-target-wwpn <text>]
- Library Target Ports-
The World Wide Port Name of a storage tape library port.
[-initiator <text>]
- Initiator-
The host bus adapter that the clustered node uses to connect to storage tape libraries.
[-array-name <array name>]
- Library Name-
Name of the storage tape library that is connected to the clustered node.
[-target-side-switch-port <text>]
- Target Side Switch Port-
This identifies the switch port that connects to the tape library's target port.
[-initiator-side-switch-port <text>]
- Initiator Side Switch Port-
This identifies the switch port that connects to the node's initiator port.
[-lun-count <integer>]
- Number of LUNS-
This is a command-line switch (-lun-count) used to restrict what LUN groups are displayed in the output.
The following example displays the storage tape library configuration information.
cluster1::> storage tape library config show LUN LUN Node Group Count Library Name Library Target Port Initiator ------------ ----- ----- ---------------------------- ----------------------- --------- cluster1-01 0 2 TAPE_LIB_1 50050763124b4d6f 3d cluster1::>
