vserver fpolicy policy external-engine delete
PDF of this doc site
Creating your file...
Your file is ready
Delete an external engine
The vserver fpolicy policy external-engine delete
command deletes an FPolicy external engine.
-vserver <Vserver Name>
- Vserver-
This parameter specifies the Vserver from which you want to delete an FPolicy external engine.
-engine-name <Engine name>
- Engine-
This parameter specifies the name of the FPolicy external engine you want to delete.
The following example deletes an FPolicy external engine.
cluster1::> vserver fpolicy policy external-engine show -vserver vs1.example.com -engine-name new_engine Vserver: vs1.example.com Engine: new_engine Primary FPolicy Servers: 1.1.1.1 Port Number of FPolicy Service: 10 Secondary FPolicy Servers: 2.2.2.2 External Engine Type: synchronous SSL Option for External Communication: mutual-auth FQDN or Custom Common Name: Sample1-FPolicy-Client Serial Number: 8DDE112A114D1FBC Certificate Authority: TASample1 cluster1::> vserver fpolicy policy external-engine delete -vserver vs1.example.com -engine-name new_engine
