storage firmware hba show
Display the list of HBA firmware files on the given node
The storage firmware hba show
command displays the HBA firmware files present on each node. For MCC configs, run the command on each DR group.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the files that match the specified node name.
[-filename <text>]
- Storage Firmware File-
Selects the files that match the specified filename.
The following example displays the HBA firmware files on each node:
cluster1::> storage firmware hba show Node: Node1 HBA Firmware Files ---------------------------------------- PM8072.03080900.HFW SAS3008.13000000.HFW SAS3616W.12030003.HFW PM8072.03080900.HFW Node: Node2 HBA Firmware Files ---------------------------------------- PM8072.03080900.HFW SAS3008.13000000.HFW SAS3616W.12030003.HFW PM8072.03080900.HFW 8 entries were displayed.
