cluster log-forwarding modify
PDF of this doc site
Creating your file...
Modify log forwarding destination settings
The cluster log-forwarding modify
command modifies log forwarding destinations for remote logging.
-destination <Remote InetAddress>
- Destination Host-
The host name or IPv4 or IPv6 address of the server to be modified.
-port <integer>
- Destination Port-
The port that the destinations servers listen on.
[-ipspace <IPspace>]
- IPspace of Destination-
The IPspace of the destination server.
[-verify-server {true|false}]
- Verify Destination Server Identity-
When this parameter is set to
true
, the identity of the log forwarding destination is verified by validating its certificate. The value can be set totrue
only when thetcp-encrypted
value is selected in the protocol field. When this value istrue
the remote server might be validated by OCSP. The OCSP validation for cluster logs is controlled with the security config ocsp enable -app audit_log and security config ocsp disable -app audit_log . [-facility <Syslog Facility>]
- Syslog Facility-
The Syslog facility to use for the forwarded logs.
[-message-format {legacy-netapp|rfc-5424}]
- Syslog Message Format-
Use this parameter to specify a new Syslog message format to replace the current message format.
[-timestamp-format-override {no-override|rfc-3164|iso-8601-utc|iso-8601-local-time}]
- Syslog Timestamp Format Override-
Use this parameter to override the default Syslog timestamp format (based on the
message-format
parameter). [-hostname-format-override {no-override|fqdn|hostname-only}]
- Syslog Hostname Format Override-
Use this parameter to override the default Syslog hostname format (based on the
message-format
parameter).
This example modifies the facility of audit logs that are forwarded to the destination server at address 192.168.0.1, port 514.
cluster1::> cluster log-forwarding modify -destination 192.168.0.1 -port 514 -facility local1
