system snmp community add
PDF of this doc site
Creating your file...
Your file is ready
Adds a new community with the specified access control type
The system snmp community add
command adds communities with the specified access control type. Only read-only communities are supported. There is no limit for the number of communities supported.
-vserver <Vserver Name>
- Vserver-
This parameter specifies the Vserver to which the community will be added. If no Vserver is specified, the community is added to the admin Vserver.
-community-name <text>
- Community-
This parameter specifies the name of the community.
-type <ctype>
- access type-
This parameter specifies 'ro' for read-only community.
The following example adds the read-only community name 'private'.
cluster1::> system snmp community add -type ro -community-name private cluster1::> system snmp community show ro private
