vserver object-store-server group modify
PDF of this doc site
Creating your file...
Modify an Object Store Server Group
The vserver object-store-server group modify
command modifies an object store group.
-vserver <Vserver Name>
- Vserver Name-
This parameter specifies the name of the Vserver for the object store group which you want to modify.
-gid <integer>
- Group ID-
This parameter specifies the ID of the object store group.
[-name <TextNoCase>]
- Group Name-
This parameter specifies the name of the object store group.
[-users <TextNoCase>,…]
- List of Users Belonging to the Group-
Use this parameter to specify the list of object store users who belong to the object store group.
[-policies <TextNoCase>,…]
- List of Policies Attached to the Group-
Use this parameter to specify the list of object store policies that are attached to the object store group.
[-comment <text>]
- Group Description-
This parameter specifies the text comment for the object store group.
The following example modifies the comment of the object store group for Vserver vs1:
cluster1::> vserver object-store-server group modify -vserver vs1 -gid 3 -comment "UserGroup"
