vserver object-store-server group modify
Modify an Object Store Server Group
The vserver object-store-server group modify command modifies an object store group.
-vserver <Vserver Name> - Vserver Name
This parameter specifies the name of the Vserver for the object store group which you want to modify.
-gid <integer> - Group ID
This parameter specifies the ID of the object store group.
[-name <TextNoCase>] - Group Name
This parameter specifies the name of the object store group.
[-users <TextNoCase>,…​] - List of Users Belonging to the Group
Use this parameter to specify the list of object store users who belong to the object store group.
[-policies <TextNoCase>,…​] - List of Policies Attached to the Group
Use this parameter to specify the list of object store policies that are attached to the object store group.
[-comment <text>] - Group Description
This parameter specifies the text comment for the object store group.
The following example modifies the comment of the object store group for Vserver vs1:
cluster1::> vserver object-store-server group modify -vserver vs1 -gid 3 -comment "UserGroup"
