The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network port delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a network port
The network port delete
command deletes a network port that is no longer physically present on the storage system.
-node {<nodename>|local}
- Node-
This specifies the node on which the port is located.
-port {<netport>|<ifgrp>}
- Port-
This specifies the port to delete.
The following example deletes port e0c from a node named node0. The command works only when the port does not physically exist on the storage system.
cluster1::*> network port delete -node node0 -port e0c
