network port delete
Delete a network port
The network port delete
command deletes a network port that is no longer physically present on the storage system.
-node {<nodename>|local}
- Node-
This specifies the node on which the port is located.
-port {<netport>|<ifgrp>}
- Port-
This specifies the port to delete.
The following example deletes port e0c from a node named node0. The command works only when the port does not physically exist on the storage system.
cluster1::*> network port delete -node node0 -port e0c
