ONTAP commands
system switch fibre-channel show
Display back-end fibre-channel switch information
The system switch fibre-channel show command displays information about all the back-end fibre-channel (FC) switches in the MetroCluster configuration. The back-end switches must have been previously added for monitoring using the system switch fibre-channel add command. If no parameters are specified, the default command displays the following information about the back-end FC switches:
  • Switch
  • Symbolic Name
  • Vendor
  • Model
  • Switch WWN
  • Is Monitored
  • Monitor Status
To display detailed profile information about a single back-end FC switch, use the -switch-name parameter.
{ [-fields <fieldname>,…​]
Displays the specified fields for all the back-end FC switches, in column-style output.
| [-connectivity ]
Displays the following details about the connectivity from the back-end FC switch to connected entities:
  • Port name
  • Port operating mode
  • Port world wide name
  • Peer port world wide name
  • Peer type
  • Additional information about peer
Displays the following details about the connectivity from the node to the back-end FC switch:
  • Node name
  • Adapter name
  • Switch port name
  • Switch port speed
  • Adapter type
| [-cooling ]
Displays the following details about the fans and temperature sensors on the back-end FC switch:
  • Fan name
  • Fan speed in rotations per minute (RPM)
  • Fan operational status
  • Temperature sensor name
  • Temperature sensor reading in Celsius ©
  • Temperature sensor status
| [-error ]
Displays the errors related to the back-end FC switch.
| [-port ]
Displays the following details about the back-end FC switch ports:
  • Port name
  • Port administrative status
  • Port operational status
  • Whether SFP is present in the port
  • Port speed in gigabits per second (Gbps)
  • Port BB credit
| [-power ]
Displays the following details about the back-end FC switch power supplies:
  • Power supply name
  • Power supply serial number
  • Power supply operational status
| [-san-config ]
Displays the following details about the Virtual Storage Area Networks (VSAN) and Zones of the back-end FC switch:
  • VSAN identifier
  • VSAN name
  • VSAN operational status
  • Type of load balancing configured for the VSAN
  • Where in-order-delivery set for the VSAN
  • Whether the auto power reset of the PSU is enabled
  • VAN member switch name and port
  • Zone name
  • VSAN ID of the zone
  • Zone member switch name and port
  • Zone member port id
  • Zone member port world wide name
| [-sfp ]
Displays the following details about the back-end FC switch ports small form-factor pluggable (SFP):
  • Port name
  • Type of SFP
  • SFP transmitter type
  • SFP vendor
  • SFP part number
  • SFP serial number
| [-stats ]
  • Port name
  • Frames received through the port (Rx Frames)
  • Frames transmitted through the port (Tx Frames)
  • Octets received through the port (Rx Octets)
  • Octets transmitted through the port (Tx Octets)
  • Port error frames
| [-instance ] }
Displays expanded information about all the back-end FC switches in the system. If a back-end FC switch is specified, then this parameter displays the same detailed information for the back-end FC switch you specify as does the -switch-name parameter.
[-switch-name <text>] - FC Switch Name
Displays information only about the back-end FC switches that match the name you specify.
[-switch-wwn <text>] - Switch World Wide Name
Displays information only about the back-end FC switches that match the switch wwn you specify.
[-switch-symbolic-name <text>] - Switch Symbolic Name
Displays information only about the back-end FC switches that match the switch symbolic name you specify.
[-switch-fabric-name <text>] - Fabric Name
Displays information only about the back-end FC switches that match the switch fabric you specify.
[-domain-id <integer>] - Switch Domain ID
Displays information only about the back-end FC switches that match the switch domain id you specify.
[-switch-role {unknown|primary|subordinate}] - Switch Role in Fabric
Displays information only about the back-end FC switches that match the switch role you specify.
[-snmp-version {SNMPv1|SNMPv2c|SNMPv3}] - SNMP Version
Displays information only about the back-end FC switches that match the switch SNMP version you specify.
[-switch-model <text>] - Switch Model
Displays information only about the back-end FC switches that match the switch model you specify.
[-switch-vendor {unknown|Brocade|Cisco}] - Switch Vendor
Displays information only about the back-end FC switches that match the switch vendor you specify.
[-fw-version <text>] - Switch Firmware Version
Displays information only about the back-end FC switches that match the switch firmware version you specify.
[-serial-number <text>] - Switch Serial Number
Displays information only about the back-end FC switches that match the switch serial number you specify.
[-switch-ipaddress <IP Address>] - Switch IP Address
Displays information only about the back-end FC switches that match the switch IP address you specify.
[-switch-status {unknown|ok|error}] - Switch Status
Displays information only about the back-end FC switches that match the switch status you specify.
[-snmp-community-or-username <text>] - SNMPv2c Community or SNMPv3 Username
Displays information only about the back-end FC switches that match the switch SNMPv2c community or SNMPv3 username you specify.
[-profile-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}] - Switch Profile Data Last Successful Refresh Timestamp
Displays information only about the back-end FC switches that match the profile data last successful refresh timestamp you specify.
[-is-monitoring-enabled {true|false}] - Is Monitoring Enabled for Switch
Displays information only about the back-end FC switches that match the switch monitoring value you specify.
[-blades <integer>,…​] - Director-Class Switch Blades to Monitor
Displays information only about the back-end FC switches that match the blade value you specify.
[-engine-id <Hex String>] - Engine ID of SNMPv3 Capable Switch
Displays information only about the back-end FC switches that match the SNMPv3 engine-id you specify.
[-psu-name-list <text>,…​] - Switch Power Supply Name List
Displays information only about the back-end FC switches that have the power supply units with the names you specify.
[-psu-serial-number-list <text>,…​] - Switch Power Supply Serial Number List
Displays information only about the back-end FC switches that have the power supply units with the serial numbers you specify.
[-psu-status-list {unknown|normal|warning|faulty|not-present}] - Switch Power Supply Status List
Displays information only about the back-end FC switches that have the power supply units with the statuses you specify.
[-psu-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}] - Switch Power Supply Data Last Successful Refresh Timestamp
Displays information only about the back-end FC switches that match the power supply unit data last successful refresh timestamp you specify.
[-temp-sensor-name-list <text>,…​] - Switch Temperature Sensor Name List
Displays information only about the back-end FC switches that have the temperature sensors with the names you specify.
[-temp-sensor-reading-list <integer>,…​] - Switch Temperature Sensor Reading © List
Displays information only about the back-end FC switches that have the temperature sensors with the readings you specify.
[-temp-sensor-status-list {unknown|normal|warning|critical}] - Switch Temperature Sensor Status List
Displays information only about the back-end FC switches that have the temperature sensors with the statuses you specify.
[-temp-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}] - Switch Temperature Sensor Data Last Successful Refresh Timestamp
Displays information only about the back-end FC switches that match the temperature sensor data last successful refresh timestamp you specify.
[-fan-name-list <text>,…​] - Switch Fan Name List
Displays information only about the back-end FC switches that match the fans with the names you specify.
[-fan-rpm-list <integer>,…​] - Switch Fan Speed (RPM) List
Displays information only about the back-end FC switches that match the fans with the RPM speeds you specify.
[-fan-status-list {unknown|operational|failed|not-operational|not-present}] - Switch Fan Operational Status List
Displays information only about the back-end FC switches that match the fans with the statuses you specify.
[-fan-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}] - Switch Fan Data Last Successful Refresh Timestamp
Displays information only about the back-end FC switches that match the fan data last successful refresh timestamp you specify.
[-vsan-index-list <integer>,…​] - Switch VSAN Index List
Displays information only about the back-end FC switches that have the VSANs with the indexes you specify.
[-vsan-name-list <text>,…​] - Switch VSAN Name List
Displays information only about the back-end FC switches that have the VSANs with the names you specify.
[-vsan-oper-status-list {up|down}] - Switch VSAN Operational Status List
Displays information only about the back-end FC switches that have the VSANs with the operational statuses you specify.
[-vsan-load-balancing-type-list {src-id-dest-id|src-id-dest-id-ox-id}] - Switch VSAN Load balancing Type List
Displays information only about the back-end FC switches that have the VSANs with the load balancing types you specify.
[-is-vsan-iod-list {true|false}] - Is In-order Delivery Set for VSAN List
Displays information only about the back-end FC switches that have the VSANs with the IOD setting you specify.
[-vsan-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}] - Switch VSAN Data Last Successful Refresh Timestamp
Displays information only about the back-end FC switches that match the VSAN data last successful refresh timestamp you specify.
[-member-switch-name-list <text>,…​] - Member Switch List
Displays information only about the back-end FC switches that have the VSANs with the member switch names you specify.
[-member-switch-port-name-list <text>,…​] - Member Switch Port Name List
Displays information only about the back-end FC switches that have the VSANs with the memeber switch port names you specify.
[-vsan-id-list <integer>,…​] - Zone VSAN ID List
Displays information only about the back-end FC switches that have the VSANs with the IDs you specify.
[-zone-name-list <text>,…​] - Switch Zone Name List
Displays information only about the back-end FC switches that have the zones with the names you specify.
[-zone-member-sw-domain-id-list <integer>,…​] - Zone Member Switch Port Domain ID List
Displays information only about the back-end FC switches that have the zones with the member switch domain ids you specify.
[-zone-member-port-name-list <text>,…​] - Zone Member Port List
Displays information only about the back-end FC switches that have the zones with the port names you specify.
[-zone-member-port-wwn-list <text>,…​] - Zone Member WWPN List
Displays information only about the back-end FC switches that have the zones with the port WWNs you specify.
[-zone-member-port-switch-name-list <text>,…​] - Zone Member Switch WWN List
Displays information only about the back-end FC switches that have the zones with the member port hosting switch names you specify.
[-zone-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}] - Switch Zone Data Last Successful Refresh Timestamp
Displays information only about the back-end FC switches that match the zone data last successful refresh timestamp you specify.
[-zone-member-wwn-list <text>,…​] - Zone Member WWN List
Displays information only about the back-end FC switches that have the zones with the member WWNs you specify.
[-zone-member-port-id-list <text>,…​] - Zone Member Port ID List
Displays information only about the back-end FC switches that have the zones with the member port ids you specify.
[-port-wwn-list <text>,…​] - Switch Port World Wide Name (WWPN) List
Displays information only about the back-end FC switches that have the ports with the WWNs you specify.
[-port-name-list <text>,…​] - Switch Port Name List
Displays information only about the back-end FC switches that have the ports with the names you specify.
[-port-admin-status-list {unknown|enabled|disabled}] - Switch Port Admin Status List
Displays information only about the back-end FC switches that have the ports with administrative statuses you specify.
[-port-oper-status-list {unknown|online|offline}] - Switch Port Operational Status List
Displays information only about the back-end FC switches that have the ports with operational statuses you specify.
[-port-mode-list {unknown|auto|F-port|FL-port|E-port|TE-port|U-port|G-port|other|EX-port|D-port|SIM-port|VE-port|AE-port|AF-port}] - Switch Port Mode List
Displays information only about the back-end FC switches that have the ports with the operating modes you specify.
[-port-oper-speed-list <integer>,…​] - Switch Port Current Speed (in Gbits/sec) List
Displays information only about the back-end FC switches that have the ports with the operational speeds you specify.
[-port-bb-credit-list <integer>,…​] - Switch Port BB Credit List
Displays information only about the back-end FC switches that have the ports with the BB credits you specify.
[-port-sfp-present-list {true|false}] - Switch Port Is SFP Present List
Displays information only about the back-end FC switches that have the ports with the SFP present values you specify.
[-port-peer-wwpn-list <text>,…​] - Switch Port Peer WWPN List
Displays information only about the back-end FC switches that have the ports with the peer port WWPNs you specify.
[-port-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}] - Switch Port Data Last Successful Refresh Timestamp
Displays information only about the back-end FC switches that match the port data last successful refresh timestamp you specify.
[-port-stat-name-list <text>,…​] - Switch Port Name List
[-port-tx-frames-list <integer>,…​] - Switch Port Transmitted Frame Count List
Displays information only about the back-end FC switches that have the ports with the transmitted frames values you specify.
[-port-rx-frames-list <integer>,…​] - Switch Port Received Frame Count List
Displays information only about the back-end FC switches that have the ports with the received frames values you specify.
[-port-tx-octets-list <integer>,…​] - Switch Port Total Transmitted Octets List
Displays information only about the back-end FC switches that have the ports with the transmitted octets values you specify.
[-port-rx-octets-list <integer>,…​] - Switch Port Total Received Octets List
Displays information only about the back-end FC switches that have the ports with the received octets values you specify.
[-port-frame-error-list <integer>,…​] - Switch Port Frame Error Count List
Displays information only about the back-end FC switches that have the ports with the error frame values you specify.
[-port-stat-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}] - Switch Port Stat Data Last Update Timestamp
Displays information only about the back-end FC switches that match the port statistics data last successful refresh timestamp you specify.
[-sfp-port-name-list <text>,…​] - Switch Port Name List
[-sfp-type-list {unknown|other|gbic|embedded|glm|gbic-with-serial-id|gbic-without-serial-id|sfp-with-serial-id|sfp-without-serial-id|xfp|x2-short|x2-medium|x2-tall|xpak-short|xpak-medium|xpak-tall|xenpak|sfp-dw-dm|qsfp|x2-dw-dm|gbic-not-installed|small-form-factor}] - Switch Port SFP Type List
Displays information only about the back-end FC switches that have the ports with the SFP types you specify.
[-sfp-tx-type-list {unknown|long-wave-laser|short-wave-laser|long-wave-laser-cost-reduced|electrical|ten-gig-base-sr|ten-gig-base-lr|ten-gig-base-er|ten-gig-base-lx4|ten-gig-base-sw|ten-gig-base-lw|ten-gig-base-ew}] - Switch Port SFP Transmitter Type List
Displays information only about the back-end FC switches that have the ports with the SFP transmitter types you specify.
[-sfp-vendor-list <text>,…​] - Switch Port SFP Vendor List
Displays information only about the back-end FC switches that have the ports with the SFP vendors you specify.
[-sfp-part-number-list <text>,…​] - Switch Port SFP Part Number List
Displays information only about the back-end FC switches that have the ports with the SFP part numbers you specify.
[-sfp-serial-number-list <text>,…​] - Switch Port SFP Serial Number List
Displays information only about the back-end FC switches that have the ports with the SFP serial numbers you specify.
[-sfp-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}] - Switch Port SFP Data Last Successful Refresh Timestamp
Displays information only about the back-end FC switches that match the port SFP data last successful refresh timestamp you specify.
[-switch-error-text-list <text>,…​] - Switch Error Text List
Displays information only about the back-end FC switches that have the errors you specify.
[-conn-switch-port-name-list <text>,…​] - Switch Port Name List
[-conn-switch-port-mode-list {unknown|auto|F-port|FL-port|E-port|TE-port|U-port|G-port|other|EX-port|D-port|SIM-port|VE-port|AE-port|AF-port}] - Switch Port Operating Mode List
[-conn-switch-port-wwn-list <text>,…​] - Switch Port WWN List
[-conn-switch-port-peer-port-wwn-list <text>,…​] - Switch Port Peer Port WWN List
Displays information only about the back-end FC switches that have the ports with the peer port WWNs you specify.
[-conn-switch-port-peer-info-list <text>,…​] - Switch Port Peer Host & Port Name List
Displays information only about the back-end FC switches that have the ports with the peer information values you specify.
[-conn-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}] - Switch Connectivity Data Last Successful Refresh Timestamp
Displays information only about the back-end FC switches that match the switch connectivity data last successful refresh timestamp you specify.
[-conn-switch-port-peer-type-list {unknown|bridge|switch|fcp-adapter|fcvi-adapter}] - Switch Port Peer Type List
Displays information only about the back-end FC switches that have the ports connected to the peer types you specify.
[-switch-port-name-list <text>,…​] - Switch Port Name List
[-switch-port-speed-list <integer>,…​] - Switch Port Speed (in Gbps) List
Displays information only about the back-end FC switches that have the ports with the speeds you specify.
[-node-name-list <nodename>,…​] - Node Name List
Displays information only about the back-end FC switches that are connected to the nodes you specify.
[-adapter-name-list <text>,…​] - Node Adapter Name List
Displays information only about the back-end FC switches that are connected to the adapters you specify.
[-adapter-port-name-list <text>,…​] - Node Adapter Port Name List
Displays information only about the back-end FC switches that are connected to the adapter ports you specify.
[-adapter-type-list {unknown|FCP-Initiator|FC-VI|FCP-Target}] - Node Adapter Type List
Displays information only about the back-end FC switches that are connected to the types of adapters you specify.
[-path-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}] - Switch Path Data Last Successful Refresh Timestamp
Displays information only about the back-end FC switches that match the node to switch path data last successful refresh timestamp you specify.
[-name-list <text>,…​] - Switch Name List
Displays information only about the back-end FC switches that match the names you specify.
[-domain-id-list <integer>,…​] - Switch Domain ID List
Displays information only about the back-end FC switches that match the domain ids you specify.
[-wwn-list <text>,…​] - Switch WWN List
Displays information only about the back-end FC switches that match the switch WWNs you specify.
[-role-list {unknown|primary|subordinate}] - Switch Role in Fabric List
Displays information only about the back-end FC switches that match the switch roles you specify.
[-address-list <IP Address>,…​] - Switch IP Address List
Displays information only about the back-end FC switches that match the switch IP addresses you specify.
The following example displays information about all back-end FC switches:
cluster::> system switch fibre-channel show
                Symbolic                                     Is        Monitor
    Switch      Name     Vendor  Model      Switch WWN       Monitored Status
    Cisco_10.226.197.34
                mcc-cisco-8Gb-fab-4
                         Cisco   DS-C9148-16P-K9
                                            2000547fee78f088 true      ok
    Cisco_10.226.197.35
                mcc-cisco-8Gb-fab-3
                                            2000547fee78f0f0 true      ok
    Cisco_10.226.197.36
                mcc-cisco-8Gb-fab-2
                                            2000547fee78efb0 true      ok
    Cisco_10.226.197.37
                mcc-cisco-8Gb-fab-1
                                            2000547fee78f0d8 true      ok
    4 entries were displayed.
cluster::>
The following example displays connectivity (switch to peer and node to switch) information about all back-end FC switches:
cluster::> system switch fibre-channel show -connectivity
          Switch Name: Cisco_10.226.197.36
           Switch WWN: 2000547fee78efb0
           Fabric WWN: 2001547fee78efb1
               Vendor: Cisco
                Model: DS-C9148-16P-K9
               Errors: -
     Last Update Time: 7/31/2014 14:16:42 -04:00
Connectivity:
Port Name Port Mode Port WWN         Peer Port WWN    Peer Type    Peer Info
     fc1/1     F-port    2001547fee78efb0 2100001086607d34 unknown      unknown
     fc1/3     F-port    2003547fee78efb0 21000024ff3dd9cb unknown      unknown
     fc1/4     F-port    2004547fee78efb0 21000024ff3dda8d unknown      unknown
     fc1/5     F-port    2005547fee78efb0 500a0980009af880 unknown      unknown
     fc1/6     F-port    2006547fee78efb0 500a0981009af370 unknown      unknown
     fc1/11    TE-port   200b547fee78efb0 200b547fee78f088 switch       Cisco_10.226.197.34:fc1/11
     fc1/12    TE-port   200c547fee78efb0 200c547fee78f088 switch       Cisco_10.226.197.34:fc1/12
     fc1/13    F-port    200d547fee78efb0 2100001086609e22 unknown      unknown
     fc1/15    F-port    200f547fee78efb0 21000024ff3dd91b unknown      unknown
     fc1/16    F-port    2010547fee78efb0 21000024ff3dbef5 unknown      unknown
     fc1/17    F-port    2011547fee78efb0 500a0981009afda0 unknown      unknown
     fc1/18    F-port    2012547fee78efb0 500a0981009a9160 unknown      unknown
     fc1/25    F-port    2019547fee78efb0 21000010866037e8 bridge       ATTO_10.226.197.17:1
     fc1/27    F-port    201b547fee78efb0 21000024ff3dd9d3 fcvi-adapter dpg-mcc-3240-15-a1:fcvi_device_1
     fc1/28    F-port    201c547fee78efb0 21000024ff3dbe3d fcvi-adapter dpg-mcc-3240-15-a2:fcvi_device_1
     fc1/29    F-port    201d547fee78efb0 500a0980009ae0a0 fcp-adapter  dpg-mcc-3240-15-a2:0c
     fc1/30    F-port    201e547fee78efb0 500a0981009aef40 fcp-adapter  dpg-mcc-3240-15-a1:0d
Last Update Time: 7/31/2014 14:26:48 -04:00
Path:
                                                      Switch
                                                        Port
     Node                 Adapter        Switch Port   Speed Adapter Type
     dpg-mcc-3240-15-a1   0d             fc1/30        4Gbps FCP-Initiator
     dpg-mcc-3240-15-a1   fcvi_device_1  fc1/27        8Gbps FC-VI
     dpg-mcc-3240-15-a2   0c             fc1/29        4Gbps FCP-Initiator
     dpg-mcc-3240-15-a2   fcvi_device_1  fc1/28        8Gbps FC-VI
The following command displays cooling (temperature sensors and fans) information about all back-end FC switches:
cluster::> system switch fibre-channel show -cooling
Switch Name: Cisco_10.226.197.34
           Switch WWN: 2000547fee78f088
               Vendor: Cisco
              Errors: -
    Last Update Time: 7/31/2014 14:26:58 -04:00
Fans:
    Fan               RPM Status
    Fan Module-1        - operational
    Fan Module-2          operational
    Fan Module-3          operational
    Fan Module-4          operational
Last Update Time: 7/31/2014 14:27:10 -04:00
Temperature Sensors:
Sensor          Temp (C) Status
    module-1 Outlet       27 normal
    module-1 Outlet       29 normal
    module-1 Intake       26 normal
    module-1 Intake       28 normal
The following command displays the error information about all back-end FC switches:
cluster::> system switch fibre-channel show -error
    Cisco_10.226.197.34(2000547fee78f088): Switch is Unreachable over Management Network.
Switch Name: Cisco_10.226.197.35
     Switch WWN: 2000547fee78f0f0
    Cisco_10.226.197.35(2000547fee78f0f0): Switch is Unreachable over Management Network.
    Cisco_10.226.197.36(2000547fee78efb0): Switch is Unreachable over Management Network.
Switch Name: Cisco_10.226.197.37
     Switch WWN: 2000547fee78f0d8
    Cisco_10.226.197.37(2000547fee78f0d8): Switch is Unreachable over Management Network.
The following command displays the detailed information about all the back-end FC switches:
cluster::> system switch fibre-channel show -instance
       Switch Domain: -
         Switch Role: -
              Vendor: Cisco
    Firmware Version: 6.2(1)
       Management IP: 10.226.197.34
              Errors: Cisco_10.226.197.34(2000547fee78f088): Switch is Unreachable over Management Network.
    Last Update Time: 7/31/2014 14:41:28 -04:00
Fabric:
Switch Name                 Domain WWN              Role        IP Address
    Cisco_10.226.197.34              0 2000547fee78f088 unknown     10.226.197.34
    Cisco_10.226.197.36              0 2000547fee78efb0 unknown     10.226.197.36
The following command displays port information about all back-end FC switches:
cluster::> system switch fibre-channel show -port
               Vendor: Cisco
              Errors: -
Ports:
                       Admin    Oper              SFP      Speed     BB
    Port Name Port WWN Status   Status  Port Mode Present (Gbps) Credit PeerPortWWN
    fc1/1     2001547fee78f088
                       enabled  online  F-port    true         8      1 2100001086608b76
    fc1/2     2002547fee78f088
                       enabled  offline auto      true         0      1
    fc1/3     2003547fee78f088
                       enabled  online  F-port    true         8      1 21000024ff48edd9
    fc1/4     2004547fee78f088
                       enabled  online  F-port    true         8      1 21000024ff3dd981
    fc1/5     2005547fee78f088
                       enabled  online  F-port    true         4      1 500a098001057f98
    fc1/6     2006547fee78f088
                       enabled  online  F-port    true         4      1 500a098101069778
    fc1/7     2007547fee78f088
    fc1/8     2008547fee78f088
    fc1/9     2009547fee78f088
    fc1/10    200a547fee78f088
                       enabled  offline auto      true         0     32
    fc1/11    200b547fee78f088
                       enabled  offline TE-port   true         8     32 200b547fee78efb0
    fc1/12    200c547fee78f088
                       enabled  offline TE-port   true         8     32 200c547fee78efb0
    fc1/13    200d547fee78f088
                       enabled  online  F-port    true         8     32 2100001086609c2e
    fc1/14    200e547fee78f088
    fc1/15    200f547fee78f088
    fc1/16    2010547fee78f088
    fc1/17    2011547fee78f088
    fc1/18    2012547fee78f088
    fc1/19    2013547fee78f088
    fc1/20    2014547fee78f088
    fc1/21    2015547fee78f088
    fc1/22    2016547fee78f088
    fc1/23    2017547fee78f088
    fc1/24    2018547fee78f088
    fc1/25    2019547fee78f088
                       enabled  online  F-port    true         8     32 2100001086609c06
    fc1/26    201a547fee78f088
    fc1/27    201b547fee78f088
                       enabled  online  F-port    true         8     32 21000024ff48ea93
    fc1/28    201c547fee78f088
                       enabled  online  F-port    true         8     32 21000024ff48eacf
    fc1/29    201d547fee78f088
                       enabled  online  F-port    true         4     32 500a098101484340
    fc1/30    201e547fee78f088
                       enabled  online  F-port    true         4     32 500a09810147e700
    fc1/31    201f547fee78f088
    fc1/32    2020547fee78f088
    fc1/33    2021547fee78f088
    fc1/34    2022547fee78f088
    fc1/35    2023547fee78f088
    fc1/36    2024547fee78f088
    fc1/37    2025547fee78f088
    fc1/38    2026547fee78f088
    fc1/39    2027547fee78f088
    fc1/40    2028547fee78f088
    fc1/41    2029547fee78f088
    fc1/42    202a547fee78f088
    fc1/43    202b547fee78f088
    fc1/44    202c547fee78f088
    fc1/45    202d547fee78f088
    fc1/46    202e547fee78f088
    fc1/47    202f547fee78f088
    fc1/48    2030547fee78f088
                       enabled  offline auto      true         0      0
    port-channel 1
              2401547fee78f088
    port-channel 2
              2402547fee78f088
    port-channel 3
              2403547fee78f088
    port-channel 4
              2404547fee78f088
    port-channel 5
              2405547fee78f088
    port-channel 6
              2406547fee78f088
    port-channel 7
              2407547fee78f088
    port-channel 8
              2408547fee78f088
    port-channel 9
              2409547fee78f088
    port-channel 10
              240a547fee78f088
    port-channel 11
              240b547fee78f088
    port-channel 12
              240c547fee78f088
    sup-fc0            enabled  online  unknown   true         1      0
The following command displays power supply unit information about all back-end FC switches:
cluster::> system switch fibre-channel show -power
               Vendor: Cisco
              Errors: -
    Last Update Time: 7/31/2014 14:41:49 -04:00
Power Supplies:
Power Supply    Serial Number Status
    300.00W 110v AC PAC15494TBZ   normal
    300.00W 110v AC PAC15494T4D   normal
The following command displays san configuration (VSANs and Zones) information about all back-end FC switches:
cluster::> system switch fibre-channel show -san-config
               Vendor: Cisco
              Errors: -
    VSAN Configuration:
Oper
    VSAN ID Vsan Name                Status Load Balancing  isIOD
          1 VSAN0001                 up     src-id-dest-id  true
          2 dpg_13_storage           up     src-id-dest-id-ox-id
                                                            true
          3 dpg_13_fcvi              down   src-id-dest-id-ox-id
                                                            true
         10 dpg_mcc_13_fab1_fcvi     up     src-id-dest-id  true
         20 dpg_mcc_13_fab1_storage  up     src-id-dest-id-ox-id
                                                            true
         30 dpg_mcc_13_fab2_fcvi     up     src-id-dest-id  true
         40 VSAN0040                 up     src-id-dest-id  true
         70 dpg_mcc_14_fcvi          up     src-id-dest-id  true
         80 dpg_mcc_14_storage       up     src-id-dest-id-ox-id
                                                            true
        110 dpg_mcc_15_fcvi          up     src-id-dest-id-ox-id
                                                            true
        120 dpg_mcc_15_storage       up     src-id-dest-id-ox-id
                                                            true
       4094 isolated_vsan            down   src-id-dest-id-ox-id
                                                            true
VSAN Membership:
VSAN ID Switch Name          Switch Port Name
          1 Cisco_10.226.197.34  fc1/2
          1 Cisco_10.226.197.34  fc1/7
          1 Cisco_10.226.197.34  fc1/8
          1 Cisco_10.226.197.34  fc1/9
          1 Cisco_10.226.197.34  fc1/10
          1 Cisco_10.226.197.34  fc1/11
          1 Cisco_10.226.197.34  fc1/12
          1 Cisco_10.226.197.34  fc1/14
          1 Cisco_10.226.197.34  fc1/19
          1 Cisco_10.226.197.34  fc1/20
          1 Cisco_10.226.197.34  fc1/21
          1 Cisco_10.226.197.34  fc1/22
          1 Cisco_10.226.197.34  fc1/23
          1 Cisco_10.226.197.34  fc1/24
          1 Cisco_10.226.197.34  fc1/31
          1 Cisco_10.226.197.34  fc1/32
          1 Cisco_10.226.197.34  fc1/33
          1 Cisco_10.226.197.34  fc1/34
          1 Cisco_10.226.197.34  fc1/35
          1 Cisco_10.226.197.34  fc1/36
          1 Cisco_10.226.197.34  fc1/37
          1 Cisco_10.226.197.34  fc1/38
          1 Cisco_10.226.197.34  fc1/39
          1 Cisco_10.226.197.34  fc1/40
          1 Cisco_10.226.197.34  fc1/41
          1 Cisco_10.226.197.34  fc1/42
          1 Cisco_10.226.197.34  fc1/43
          1 Cisco_10.226.197.34  fc1/44
          1 Cisco_10.226.197.34  fc1/45
          1 Cisco_10.226.197.34  fc1/46
          1 Cisco_10.226.197.34  fc1/47
          1 Cisco_10.226.197.34  fc1/48
          1 Cisco_10.226.197.34  port-channel 1
          1 Cisco_10.226.197.34  port-channel 2
          1 Cisco_10.226.197.34  port-channel 3
          1 Cisco_10.226.197.34  port-channel 4
          1 Cisco_10.226.197.34  port-channel 5
          1 Cisco_10.226.197.34  port-channel 6
          1 Cisco_10.226.197.34  port-channel 7
          1 Cisco_10.226.197.34  port-channel 8
          1 Cisco_10.226.197.34  port-channel 9
          1 Cisco_10.226.197.34  port-channel 10
          1 Cisco_10.226.197.34  port-channel 11
          1 Cisco_10.226.197.34  port-channel 12
          1 Cisco_10.226.197.36  fc1/2
          1 Cisco_10.226.197.36  fc1/7
          1 Cisco_10.226.197.36  fc1/8
          1 Cisco_10.226.197.36  fc1/9
          1 Cisco_10.226.197.36  fc1/10
          1 Cisco_10.226.197.36  fc1/11
          1 Cisco_10.226.197.36  fc1/12
          1 Cisco_10.226.197.36  fc1/14
          1 Cisco_10.226.197.36  fc1/19
          1 Cisco_10.226.197.36  fc1/20
          1 Cisco_10.226.197.36  fc1/21
          1 Cisco_10.226.197.36  fc1/22
          1 Cisco_10.226.197.36  fc1/23
          1 Cisco_10.226.197.36  fc1/24
          1 Cisco_10.226.197.36  fc1/26
          1 Cisco_10.226.197.36  fc1/31
          1 Cisco_10.226.197.36  fc1/32
          1 Cisco_10.226.197.36  fc1/33
          1 Cisco_10.226.197.36  fc1/34
          1 Cisco_10.226.197.36  fc1/35
          1 Cisco_10.226.197.36  fc1/36
          1 Cisco_10.226.197.36  fc1/37
          1 Cisco_10.226.197.36  fc1/38
          1 Cisco_10.226.197.36  fc1/39
          1 Cisco_10.226.197.36  fc1/40
          1 Cisco_10.226.197.36  fc1/41
          1 Cisco_10.226.197.36  fc1/42
          1 Cisco_10.226.197.36  fc1/43
          1 Cisco_10.226.197.36  fc1/44
          1 Cisco_10.226.197.36  fc1/45
          1 Cisco_10.226.197.36  fc1/46
          1 Cisco_10.226.197.36  fc1/47
          1 Cisco_10.226.197.36  fc1/48
         30 Cisco_10.226.197.34  fc1/3
         30 Cisco_10.226.197.34  fc1/4
         30 Cisco_10.226.197.36  fc1/3
         30 Cisco_10.226.197.36  fc1/4
         40 Cisco_10.226.197.34  fc1/1
         40 Cisco_10.226.197.34  fc1/5
         40 Cisco_10.226.197.34  fc1/6
         40 Cisco_10.226.197.36  fc1/1
         40 Cisco_10.226.197.36  fc1/5
         40 Cisco_10.226.197.36  fc1/6
         70 Cisco_10.226.197.34  fc1/15
         70 Cisco_10.226.197.34  fc1/16
         70 Cisco_10.226.197.36  fc1/15
         70 Cisco_10.226.197.36  fc1/16
         80 Cisco_10.226.197.34  fc1/13
         80 Cisco_10.226.197.34  fc1/17
         80 Cisco_10.226.197.34  fc1/18
         80 Cisco_10.226.197.36  fc1/13
         80 Cisco_10.226.197.36  fc1/17
         80 Cisco_10.226.197.36  fc1/18
        110 Cisco_10.226.197.34  fc1/26
        110 Cisco_10.226.197.34  fc1/27
        110 Cisco_10.226.197.34  fc1/28
        120 Cisco_10.226.197.34  fc1/25
        120 Cisco_10.226.197.34  fc1/29
        120 Cisco_10.226.197.34  fc1/30
        120 Cisco_10.226.197.36  fc1/25
        120 Cisco_10.226.197.36  fc1/29
        120 Cisco_10.226.197.36  fc1/30
Last Update Time: 7/31/2014 14:45:40 -04:00
Zone Configuration:
   Member            Member      Member
   Zone Name VSAN ID Switch Name Port Name Port ID Member WWN
   dpg_mcc_fcvi   30 Cisco_10.226.197.36
                                 fc1/3     -
   $default_zone$ 30 Cisco_10.226.197.36
                                 fc1/4
   dpg_mcc_storage
                                 fc1/1
   $default_zone$ 40 Cisco_10.226.197.36
                                 fc1/5
   dpg_mcc_14_fcvi
                                 fc1/15
   $default_zone$ 70 Cisco_10.226.197.36
                                 fc1/16
   dpg_mcc_14_storage
                                 fc1/13
   $default_zone$ 80 Cisco_10.226.197.34
                                 fc1/17
   dpg_mcc_15_fcvi
                 110 Cisco_10.226.197.36
                                 fc1/27
   $default_zone$
                                 fc1/28
   dpg_mcc_15_storage
                                 fc1/25
   $default_zone$
                                 fc1/29
The following command displays port SFP information about all back-end FC switches:
cluster::> system switch fibre-channel show -sfp
               Vendor: Cisco
              Errors: -
SFP:
Port Name Type          Tx Type          Vendor      Part Number Serial Number
    fc1/1     sfp-with-serial-id
                            short-wave-laser CISCO-FINISAR
                                                          FTLF8528P2BCV-CS
        FNS160629J9
    fc1/2     unknown       unknown
    fc1/3     sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629H3
    fc1/4     sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629QH
    fc1/5     sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160628EA
    fc1/6     sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629QT
    fc1/7     unknown       unknown
    fc1/8     unknown       unknown
    fc1/9     unknown       unknown
    fc1/10    unknown       unknown
    fc1/11    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629GP
    fc1/12    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS16061X71
    fc1/13    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629P8
    fc1/14    unknown       unknown
    fc1/15    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629JP
    fc1/16    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160628D2
    fc1/17    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629NG
    fc1/18    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629R1
    fc1/19    unknown       unknown
    fc1/20    unknown       unknown
    fc1/21    unknown       unknown
    fc1/22    unknown       unknown
    fc1/23    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629NC
    fc1/24    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160628CX
    fc1/25    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629NZ
    fc1/26    unknown       unknown
    fc1/27    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS16061XB0
    fc1/28    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS16061XA6
    fc1/29    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS16061XA0
    fc1/30    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS16061X9S
    fc1/31    unknown       unknown
    fc1/32    unknown       unknown
    fc1/33    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS16061NL7
    fc1/34    unknown       unknown
    fc1/35    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629M8
    fc1/36    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629KH
    fc1/37    unknown       unknown
    fc1/38    unknown       unknown
    fc1/39    unknown       unknown
    fc1/40    unknown       unknown
    fc1/41    unknown       unknown
    fc1/42    unknown       unknown
    fc1/43    unknown       unknown
    fc1/44    unknown       unknown
    fc1/45    unknown       unknown
    fc1/46    unknown       unknown
    fc1/47    unknown       unknown
    fc1/48    unknown       unknown
    port-channel 1
              unknown       unknown
    port-channel 2
              unknown       unknown
    port-channel 3
              unknown       unknown
    port-channel 4
              unknown       unknown
    port-channel 5
              unknown       unknown
    port-channel 6
              unknown       unknown
    port-channel 7
              unknown       unknown
    port-channel 8
              unknown       unknown
    port-channel 9
              unknown       unknown
    port-channel 10
              unknown       unknown
    port-channel 11
              unknown       unknown
    port-channel 12
              unknown       unknown
    sup-fc0
The following command displays port statistics information about all back-end FC switches:
cluster::> system switch fibre-channel show -stats
               Vendor: Cisco
              Errors: -
Port Statistics:
                           Rx           Rx           Tx           Tx        Error
    Port Name          Frames       Octets       Frames       Octets       Frames
    fc1/1          2116207233   3710682580   3906335374    859905888            0
    fc1/2                   1          208            1          208            0
    fc1/3          3238899002    903116292   3079548736   4014304952            0
    fc1/4          1888758418   1643379900   2434821325   2997002344            0
    fc1/5          3719731908   1808138824   1878240211   3421335100            0
    fc1/6          2644430347   1042009564    249190625   2003353056            0
    fc1/7                   1          228            1          228            0
    fc1/8                   1          156            1          156            0
    fc1/9                   1          148            1          148            0
    fc1/10                  1          224            1          224            0
    fc1/11         3617142898   4129927136     39089396   2595464620            0
    fc1/12          473603889   1560909460   2797562521   2833496016            0
    fc1/13         1852255936   1091902804    180309704   1769859928            0
    fc1/14                  1          140            1          140            0
    fc1/15            4997082   3519688264      4283938   3370856432            0
    fc1/16            4995287   3519577592      4282173   3370732136            0
    fc1/17           55146756    178045212   1733567096   3030415436            0
    fc1/18           63005788   4287094736   1726651844   2640371212            0
    fc1/19                  1          200            1          200            0
    fc1/20                  1          104            1          104            0
    fc1/21                  1          108            1          108            0
    fc1/22                  1          108            1          108            0
    fc1/23                  1          164            1          164            0
    fc1/24                  1          216            1          216            0
    fc1/25         2810698819   1611009260    471527156   1900246656            0
    fc1/26                  1          104            1          104            0
    fc1/27         4165019838    887421780   3848122102   2581891136            0
    fc1/28           58607737   1015197080    101621078   3482734024            0
    fc1/29         4266270960    222242144   3766674764   2400640552            0
    fc1/30         3984658378   1443835508    152597387    678837848            0
    fc1/31                  1          220            1          220            0
    fc1/32                  1          120            1          120            0
    fc1/33                  1          132            1          132            0
    fc1/34                  1          144            1          144            0
    fc1/35                  1          160            1          160            0
    fc1/36                  1          104            1          104            0
    fc1/37                  1          148            1          148            0
    fc1/38                  1          184            1          184            0
    fc1/39                  1          160            1          160            0
    fc1/40                  1          136            1          136            0
    fc1/41                  1          196            1          196            0
    fc1/42                  1          128            1          128            0
    fc1/43                  1          168            1          168            0
    fc1/44                  1          212            1          212            0
    fc1/45                  1          136            1          136            0
    fc1/46                  1          224            1          224            0
    fc1/47                  1          104            1          104            0
    fc1/48                  1          104            1          104            0
