system services ndmp kill
PDF of this doc site
Creating your file...
Your file is ready
Kill the specified NDMP session
The system services ndmp kill
command is used to terminate a specific NDMP session on a particular node in the cluster.
<integer>
- Session Identifier-
Session ID of the NDMP session.
The following example shows how a specific NDMP session on the node named node1 can be terminated:
cluster1::> system services ndmp kill 4323 -node node1
