system switch ethernet log show
PDF of this doc site
Creating your file...
Display Ethernet switch log information.
The system switch ethernet log show
command displays the status and requests for Ethernet switch logs.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
Specifies an instance of the Ethernet switch devices log status.
[-device <text>]
- Switch Name-
Specifies the name of the Ethernet switch device to display log status on.
[-log-request {true|false}]
- Requested Log-
Specifies the state of the log request for an Ethernet switch device. Values: true, false.
[-log-status <text>]
- Log Status-
Specifies the status of the log request for an Ethernet switch device.
[-log-timestamp <MM/DD/YYYY HH:MM:SS>]
- Log Timestamp-
Specifies the completion timestamp of the log request for an Ethernet switch device.
[-idx <integer>]
- Index-
Specifies the index of the Ethernet switch device.
[-filename <text>]
- Filename-
Specifies the full filename of the Ethernet switch log.
[-filenode <text>]
- File Node-
Specifies the name of the controller on which the Ethernet switch log resides.
cluster1::> system switch ethernet log show Log Collection Enabled: true Index Switch Log Timestamp Status ------ ------------------------------------ ------------------- ------------- 1 switch-name01(Switch---SN) - - 2 switch-name02(Switch---SN) - -
Displays the Ethernet switches, their last log timestamp, and the status of the last log request.
