ONTAP commands
system switch ethernet log show
Display Ethernet switch log information.
The system switch ethernet log show command displays the enablement and status of the hourly collection of periodic data and the status of the collection of detailed support logs.
{ [-fields <fieldname>,…​]
| [-instance ] }
If this parameter is specified, the command displays information about all entries.
[-device <text>] - Switch Name
If this parameter is specified, the command only displays log collection details of the provided Ethernet switch(es).
[-support-requested {true|false}] - Support Log Requested
If this parameter is specified, the command only displays log collection details of the Ethernet switch(es) with support log collection requested (true ) or not requested (false ).
[-support-timestamp <MM/DD/YYYY HH:MM:SS>] - Last Support Log Timestamp
If this parameter is specified, the command only displays log collection details of the Ethernet switch(es) with the provided timestamp for periodic log collection.
[-support-filename <text>] - Support Log Filename
If this parameter is specified, the command only displays log collection details of the Ethernet switch(es) with the provided path for support log collection.
[-periodic-enabled {true|false}] - Periodic Log Enabled
If this parameter is specified, the command only displays log collection details of the Ethernet switch(es) with periodic log collection enabled (true ) or disable (false ).
[-support-state {never-run|initiated|in-progress|completed|failed}] - Support Log State
If this parameter is specified, the command only displays log collection details of the Ethernet switch(es) with the provided state; never-run , initiated , in-progress , completed , or failed
[-support-status-msg <text>] - Support Log Status
If this parameter is specified, the command only displays log collection details of the Ethernet switch(es) with the provided status message for support log collection.
[-periodic-state {never-run|scheduled|in-progress|halted|failed}] - Periodic Log State
If this parameter is specified, the command only displays log collection details of the Ethernet switch(es) with the provided state; either never-run , scheduled , in-progress , halted , or failed .
[-periodic-status-msg <text>] - Periodic Log Status
If this parameter is specified, the command only displays log collection details of the Ethernet switch(es) with the provided status message for periodic log collection.
[-periodic-timestamp <MM/DD/YYYY HH:MM:SS>] - Last Periodic Log Timestamp
[-periodic-filename <text>] - Periodic Log Filename
If this parameter is specified, the command only displays log collection details of the Ethernet switch(es) with the provided path for periodic log collection.
cluster1::> system switch ethernet log show
Periodic    Periodic    Support
            Switch                                    Log Enabled Log State   Log State
            switch-name01(Switch---SN)                true        scheduled   failed
            switch-name02(Switch---SN)                false       failed      -
Displays the Ethernet switches, their periodic log collection enablement, their periodic log collection state, and their support log collection state.
